SSS with objects inside - how to
nmn
how would you go in houdini to do an sss effect with an object inside ?
in fact all i know about sss in houdini is that first we have to generate the point scatter file then use it in the sss material.
so any tips about sss in houdini would also be much appreciated.
an example of sss with object inside :
and one other quesion
how would would make an object emitting light or a normal light inside of an object with sss ...
regards
Edited by nmn
