nmn Posted April 18, 2009 Share Posted April 18, 2009 (edited) Hi everyone, well the title explains the thing ... where did the view dependant photon map generation disappeared in v10 ?!! was it replaced by something else, or should it be added explicitly ... or what... i did a simple test by saving a scene in 9.5 with the render engine set to view-dependant ... and when i open it in 10 it shows up normally as in the 9.5 but it gives a render error when i try to render it :S:S and if i try to obtain the same result with photon map generatino instead of view dependant it says 'Computing energy from 0 lights for 100000 photons' so it doesn't work, while in 9.5 this same one works well (in fact i don't have lights in my scene, but object with constant color that i'm using as light emitter) Thanks for your answer guys Best Regards Edited April 20, 2009 by nmn Quote Link to comment Share on other sites More sharing options...
