Editing vertex attributes
Guest YoBeardMaestro
How would I go about manipulating the uv attribute of each vertex im my geometry? I'd like to add a random offset to each vertex uv per primitive (not per vertex). The Vertex SOP doesn't let me access the uv attribute and the Primitive SOP only permits integer offsets of uv.
The only workaround I've found so far is to promote my vertex uv's to point attributes, promote the primitive offset attribute to points, and combine both in a VOP SOP. Doesn't seem very elegant, and wont work if my points are shared between primitives.
Any ideas?
YBM.
You're absolutely right. I guess one shouldn't work into the early hours of the morning and expect to think coherently...
Thanks,
YBM.
