mblandr Posted June 17, 2009 Share Posted June 17, 2009 Well, I think it's bugs: 1)Ctrl+B shortcut dosn't synchronized with button 'Maximize pane', so pane can be not maximized, but button pressed and vice versa 2)W on the split view, when in Display option "Apply operation to all split views " unchecked, dosn't synchronized with icon on "Display geometry" and with "Draw" list in Display options 3)RMB click on pane tabs show radio checked for CURRENT tab, but changing it pane type changing for pne tab UNDER cursor, and AFTER this change RMB on pane tabs show radio for CHANGED tabs, but not CURRENT and not under cursor 4)Alt+/ close pane TAB, not PANE 5)Ctrl+W, Ctrl+B dosn't work for help pane tab, but in pane tab operations menu this menu items work well. 6)from SELECT tool shortcut Y for Show Handle tool dosn't work, only Enter, but from Scale, Move, Rotate- both Y and Enter worked Am I right? Quote Link to comment Share on other sites More sharing options...
