Piston OTL
Hello some time ago I buy buzz dvds about rigging and now I have little time to learn riggs in houdini. Im creating asset for easy building pistons with spiral. I have little problem. I thing all is ok but houdini has still error. When I creating spiral with point sop, taking parameters from otl custom sliders, I have still error, path ewerithing is ok. There is little file, Just look at the inside of otl spring sop and there is point sop. Idea is that I have two locators and between this is spiral. so I could change lenght of spiral thanks locators. I dont know where is mistake, no sence...sorry for that stupid questions but Im frustrated form this....BC....
piston_03.hip
piston_03.hip
After opening your hip file, I get a warning in the piston node about an incomplete asset. In the obj/piston/spring object I see a warning about a bad param reference. Maybe what you have in the circle node is referencing things incorrectly? Check the paths in the various channels.
thanks a lot guys, thanks for scene, Ill look at it later, must sleep hih, Ill try spiral from scratch, but My paths is all ok, some little mistake must be there. Grrrr hate this :) If has somebody little time, will be happy to say me what is wrong, just for understanding problems. Thanks again....BC....
