alpotnis Posted August 4, 2009 Share Posted August 4, 2009 hi .. i am using billowy smoke pyro and the movement looks good ... now i wanted to have 'scattering' option in the materials (shop) ... is this 'scattering' option available only with flame pyro ?? Quote Link to comment Share on other sites More sharing options...
Akabane Posted August 17, 2009 Share Posted August 17, 2009 Hi man. If you create a "VEX Pyro" shader into the shop, you have access to the scattering, modifiers (field & noise) and so on. Then use that shader, turn off "Fire visibility" if it's turned on, and start playing with the fields, interpolation, ramps etc.. Have fun Quote Link to comment Share on other sites More sharing options...
