evaluating expression in python problem
wolf_cub_one
Hey everyone,
I have a simple problem which deals with how python evaluates expressions. If I write for example:
object.parm('dirx').set(90)
My object's x direction parameter is set to 90. However, what I want is to use an expression instead like for example:
object.parm('dirx').set(sin($F * 10))
What is the proper syntax to get this to work?
Thanks for any help
Hey Graham,
Thanks. I tried setExpression before I posted but it didn't work. Then I look more closely at what you wrote and realized that I forgot to encase the whole expression in double quotes. Also since, I already had double quotes in the actual expression that I'm writing that I needed to enclosed the whole expression in single quotes. It's always the simple stuff that gets you.
Thanks again for the help
