Pop-up window
Div
I'm working on a exporter tool in python (called from a shelf tool) and I'd like to pop up a new window with some export options. I know it could be easily set up using wxPython, but as i want the tool to be self-installing, I can only use houdini's built-in modules. I've tried to create a node and set parms on it, but I haven't found a way to pop up a floating pane with only these parms. I use the createFloatingPanel() and createFloatingPaneTab() fonctions, but I can't find a way to make them show only the parms i want, i mean it works only when i select manually my created node after the function's call. Is there a way to automatically select this node by script, or another solution to do the thing ?
Thanks a lot for your help.
Edited by Div
