Getting maximum value of attribute
simonj
Hi!
I'm a little bit stuck.
I have a RBD fractured object which contains 4 diffent groups of geometry. Before I send in the data to be processed in a custom Force VOP I'd like to find the piece with the maximum mass in the groups, and return this mass.
So it looks like this:
obj1 - mass: 32
obj2 - mass: 210
obj3 - mass: 150
obj4 - mass: 80
In a custom parameter in my Force VOP I want to have an expression that would loop through/search the different groups and return the mass of the group with the highest mass: 210.
Come to think of it, I have no good way of doing this in SOPs either..
Can anyone help me out? :)
Cheers,
Simon J
Hi!
obj1 - mass: 32
obj2 - mass: 210
obj3 - mass: 150
obj4 - mass: 80
This is the sort of thing that's much easier in Python. So put a Python expression into the parameter of the Force VOP and put something like this in it:
max(p.findSubData("Position").options().field("mass") for p in pwd().simulation().objects())
The only problem is that HOM doesn't yet support DOP Object groups, so at the moment you have to get trickier if you want to limit this expression to only a certain group of objects.
Some version AttributePromote with "Promotion Method" set to "Maximum" will often do the trick.
Thanks man, it worked great. :)
Sure thing. One more quick thought: you can actually get around the no groups in HOM problem a bit if all the objects you care about were created by the same DOP node (say, a RBD Fractured Object). If the name of the node that creates the pieces is named "obj" for example, you could write:
max(p.findSubData("Position").options().field("mass") for p in node("../obj").createdObjects())
and that would restrict the expression to only those objects created by that node. Groups are still the better way to go once HOM support them, but this might be a good workaround. Also, if for some reason you need the mass to show up on the first frame, checking "Solve on Creation Frame" will tell DOPs to do the volume/mass calculations as soon as the objects are created.
