blackchicken Posted August 25, 2009 Share Posted August 25, 2009 Hello I have little problem with I3D. I use it first time instead of sprites, just for learn. It is missile trail from my little project. I choose the simplest way. Particles, copy metaballs, render meta as wolume and then fix belowy smoke. So On the video you can see my flickering problem, Shadows should be good, It is simple take, own light depp 3*3 samples. But I thing problem is with metaballs. They must have small radius, and mesh change over simulation almost every frame. What is a workflow with rendering particles and meta, some rest positions or.....Convert meta and then use ISO offset? I search some topic about I3D, but nothing about basic stable setups with different techniques. Thanks a lot....BC.... raiders.mov Quote Link to comment Share on other sites More sharing options...
jacob clark Posted August 26, 2009 Share Posted August 26, 2009 Hi, My first guess would be your shadow maps. Is there flickering in your alpha? cheers, -j Quote Link to comment Share on other sites More sharing options...
blackchicken Posted September 4, 2009 Author Share Posted September 4, 2009 thanks a lot for reply, sorry for long time to post but little holiday , in alfa smoke flickering too. There is little scene, I dont understant metaballs. There is a lot of particles, but If I scale it, they has wery low res mesh. Just look at it. How is the worklow with this system? Thanks a lot...BC... help+smoke.hip Quote Link to comment Share on other sites More sharing options...
