essencevfx Posted September 2, 2009 Share Posted September 2, 2009 (edited) I've got a temp field that I'm having to rapidly cool for an effect, ...so much so , that the smoke density is really behaving un-naturally. There has to be a way to clamp the temp field range, but for the life of me i cant find it in the solver (pyro)...Im able to control nicely the dissipation of the field with a dissipate DOP or gas calculate, but can't find a way to clamp how hi or lo the fields actually go.Thanks for any ideas .... Edited September 2, 2009 by essencevfx Quote Link to comment Share on other sites More sharing options...
louis Posted September 3, 2009 Share Posted September 3, 2009 I've got a temp field that I'm having to rapidly cool for an effect, ...so much so , that the smoke density is really behaving un-naturally. There has to be a way to clamp the temp field range, but for the life of me i cant find it in the solver (pyro)...Im able to control nicely the dissipation of the field with a dissipate DOP or gas calculate, but can't find a way to clamp how hi or lo the fields actually go.Thanks for any ideas .... you should be able to do this with the "Gas Field Vop" dop node Quote Link to comment Share on other sites More sharing options...
essencevfx Posted September 3, 2009 Author Share Posted September 3, 2009 ahhh , cool , so the globals in the volume vop only inculde density ? ...so I suppose I could just create my tempurature field as a parameter and feed that through a clamp operator , could it be that simple ? Quote Link to comment Share on other sites More sharing options...
