Fur & DOPS problem
bdunaway
I'm using Houdini 9.1.244 and following along with the DT Dynamics tutorials, specifically the wire deformers with fur. I created the basic grass setup and got the dynamics working just fine, but when I plug-in the Fur node it breaks and the error listed is "The two sources have unmatched geometry."
What am I doing wrong here?
Edited by bdunaway
UPDATE: Nevermind, apparently at some point the skin and guide inputs got changed on the Fur node just to confuse me? Switching them fixed it. Also, why is it you try everything you can think of to solve a problem, and then the minute after you post you figure out something simple so you can look like an idiot. :P
  • 4 months later...
Hi there,
I am trying to create a grass sim, so many different ways to go about it is making my head spin. Can you please tell me where you found the tutorial for setting up grass? A few people have posted the sidefx tutorials page but no mention of which one it is, or even if there is one that can help set it up.
Thank you in advance!
Hi there,
Why need a tutorial when there is an example file in the help? Just open up the help and type in 'grass'. The first thing that pops up should be a grass example file with a DOPs wire setup for the motion.
-Ryan
