sbdspring constraint
vfxkid
hi i am having some problem with sbd spring constraints. I tried to connect cloth object using sbd spring constraint with rbd object and trying to use some forces on the cloth obj to drive the rbd object but then the rbd object does not want to respond to anything or forces.
for example adding gravity force at the end of the dop sim and it just stands still. Is there any particular collision setup for cloth to effect rbd object using sbd constraints.
is it possible to use cloth to drive the rbd sim?
thanks
Edited by vfxkid
