rd1010 Posted September 3, 2009 Share Posted September 3, 2009 (edited) (I mean transparency map.. not opacity map) I've been trying to do this where I use a displacement map along with a transparency map in an object but it seems to be showing part of the displacement map in this semi-transparent way in places where it should be transparent (based on the opacity map). I'm wondering if anyone else does this sort of thing / if you know if it is possible.. I am still playing around with it to see if I can figure it out. Here is the houdini file I am trying this with.. no matter what it is showing some glare over areas that should be transparent http://rick-dane-files.s3.amazonaws.com/disp-map-with-opacity-problem.hipnc thanks for any help on this Edited September 3, 2009 by rd1010 Quote Link to comment Share on other sites More sharing options...
