greenViolet Posted September 4, 2009 Share Posted September 4, 2009 Hi, I'm very new in Houdini and I really need help Please view the hip file I attached to see my file. I created a bunch of sphere moving together in a waveform fashion (animated from CHOP) I created the spheres by copying one sphere to a line (with 10 points), now my question is, is there anyway I could assign specific color to each of the copied sphere? right now I'm using color node and stamp them to randomize the color but this is not what i want, i want each sphere to have specific color of my choice(e.g: red, yellow, green) Any help would be greatly appreciated Thanks! wavePart_LeftStart_01(ChangeColor).hipnc Quote Link to comment Share on other sites More sharing options...
sam.h Posted September 4, 2009 Share Posted September 4, 2009 Use the paint node to colour the points on the line. Then on the copy node tick on 'use template point attributes'. You can replace the * with Cd if you don't want the spheres to inherit any other attributes. Quote Link to comment Share on other sites More sharing options...
greenViolet Posted September 4, 2009 Author Share Posted September 4, 2009 Use the paint node to colour the points on the line. Then on the copy node tick on 'use template point attributes'. You can replace the * with Cd if you don't want the spheres to inherit any other attributes. Thanks, I will give it a try! Quote Link to comment Share on other sites More sharing options...
greenViolet Posted September 7, 2009 Author Share Posted September 7, 2009 Thanks Sam.h, that worked however I have to put the paint node after the copy and also assign a uv project to it... thanks a bunch! Quote Link to comment Share on other sites More sharing options...
