static Posted September 6, 2009 Share Posted September 6, 2009 As the topic suggests, I'm trying to install apprentice (10.0.374-linux_x86_64_gcc4.3) on Ubuntu 9.04. I ran into a few errors regarding pushd: command not found in my first attempt, but after recreating the shell link to bash it fixed the problem. Now I have some bigger issues... I ran the install script as: sudo ./houdini.install Here's the install in the terminal: Here are the choices you have made so far: Modules chosen to install: houdini (apprentice-licensing) Location for installation: /opt/hfs10.0.374 Disk Space Required for installation: 545 Mbytes Choose yes to proceed with the installation. Otherwise you may return to the choice menu to change your selections. Would you like to start the installation? (y or n) [y] ==> y 545060K is the space required to install selections... 261849348K is available on /opt/hfs10.0.374 Commencing installation of selected modules. This may take a few minutes... Installing: Houdini in /opt/hfs10.0.374 /opt/hfs10.0.374/python/bin/python: line 10: /opt/hfs10.0.374/python/bin/python2.5-bin: cannot execute binary file /opt/hfs10.0.374/python/bin/python: line 10: /opt/hfs10.0.374/python/bin/python2.5-bin: Success /opt/hfs10.0.374/python/bin/python: line 10: /opt/hfs10.0.374/python/bin/python2.5-bin: cannot execute binary file /opt/hfs10.0.374/python/bin/python: line 10: /opt/hfs10.0.374/python/bin/python2.5-bin: Success Installing apprentice license... The Houdini 10.0.374 environment has been initialized. /opt/hfs10.0.374/bin/hkey: line 8: /opt/hfs10.0.374/bin/hkey-bin: cannot execute binary file /opt/hfs10.0.374/bin/hkey: line 8: /opt/hfs10.0.374/bin/hkey-bin: Success Error installing apprentice license chown: cannot access `/home/blair/houdini10.0': No such file or directory Houdini install successful Houdini 10.0 Installation completed. Please read /opt/hfs10.0.374/Readme.txt for instructions on how to run Houdini. We hope you enjoy using Houdini 10.0 Thank you. Here's what happens when I source houdini_setup_bash (or just houdini_setup): blair@Blair-Linux:~$ cd /opt/hfs10.0.374/ blair@Blair-Linux:/opt/hfs10.0.374$ source houdini_setup_bash The Houdini 10.0.374 environment has been initialized. blair@Blair-Linux:/opt/hfs10.0.374$ houdini /opt/hfs10.0.374/bin/houdini: line 8: /opt/hfs10.0.374/bin/houdini-bin: cannot execute binary file /opt/hfs10.0.374/bin/houdini: line 8: /opt/hfs10.0.374/bin/houdini-bin: Success blair@Blair-Linux:/opt/hfs10.0.374$ Here's a list of the environment variables, after sourcing houdini setup: HOUDINI_BUILD_LIBC glibc 2.9 HOUDINI_VERSION 10.0.374 GNOME_DESKTOP_SESSION_ID this-is-deprecated HFS /opt/hfs10.0.374 HT /opt/hfs10.0.374/toolkit HOUDINI_BUILD_VERSION 374 HH /opt/hfs10.0.374/houdini LOGNAME blair USER blair HOME /home/blair HB /opt/hfs10.0.374/bin PATH /opt/hfs10.0.374/bin:/opt/hfs10.0.374/houdini/sbin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games LD_LIBRARY_PATH /opt/hfs10.0.374/dsolib HDSO /opt/hfs10.0.374/dsolib SSH_AGENT_PID 3888 HSB /opt/hfs10.0.374/houdini/sbin HHC /opt/hfs10.0.374/houdini/config TERM xterm SHELL /bin/bash XDG_SESSION_COOKIE 5615b84e19a08046301d87eb4a5fd4af-1252190862.155462-1689522447 TEMP /tmp SESSION_MANAGER local/Blair-Linux:/tmp/.ICE-unix/3597 SHLVL 1 HOUDINI_BUILD_COMPILER 4.3.3 DBUS_SESSION_BUS_ADDRESS unix:abstract=/tmp/dbus-gMDRw0jmHM,guid=33881c5b82e140dd28ad319f4aa2ea8e WINDOWID 23075484 HD /opt/hfs10.0.374/demo HOUDINI_MAJOR_RELEASE 10 HIH /home/blair/houdini10.0 WINDOWPATH 7 GPG_AGENT_INFO /tmp/seahorse-n1otcd/S.gpg-agent:3911:1 USERNAME blair LANG en_US.UTF-8 GDM_XSERVER_LOCATION local COLORTERM gnome-terminal H /opt/hfs10.0.374 SSH_AUTH_SOCK /tmp/keyring-Os1Ndh/socket.ssh DESKTOP_SESSION default GDMSESSION default HIS /opt/hfs10.0.374/houdini LESSCLOSE /usr/bin/lesspipe %s %s LESSOPEN | /usr/bin/lesspipe %s _ /usr/bin/python HOUDINI_BUILD_KERNEL 2.6.28-13-vserver ORBIT_SOCKETDIR /tmp/orbit-blair GNOME_KEYRING_PID 3584 GNOME_KEYRING_SOCKET /tmp/keyring-Os1Ndh/socket HOUDINI_MINOR_RELEASE 0 DISPLAY :0.0 GTK_MODULES canberra-gtk-module OLDPWD /home/blair GDM_LANG en_US.UTF-8 XAUTHORITY /home/blair/.Xauthority HISTCONTROL ignoreboth XDG_DATA_DIRS /usr/local/share/:/usr/share/:/usr/share/gdm/ PWD /opt/hfs10.0.374 HOUDINI_BUILD_PLATFORM Debian 5.0 GTK_RC_FILES /etc/gtk/gtkrc:/home/blair/.gtkrc-1.2-gnome2 I'm not sure what could be causing the error, so I did some other miscellaneous checks just to see if gcc was installed correctly and which shell I was using: blair@Blair-Linux:~$ which gcc /usr/bin/gcc blair@Blair-Linux:~$ which gcc-4.3 /usr/bin/gcc-4.3 blair@Blair-Linux:~$ echo $SHELL /bin/bash Anyone have any ideas? Tempted to say I have a faulty Ubuntu install Quote Link to comment Share on other sites More sharing options...
Alanw Posted September 8, 2009 Share Posted September 8, 2009 (edited) Anyone have any ideas? Tempted to say I have a faulty Ubuntu install I would try the download listed as gcc 4.2 "Debian 64-bit Linux (lenny)*" before messing with Ubuntu. I didn't even realize sidefx had released a version for gcc 4.3. I'm going to try it on my Fedora 10 box when I get home and see how it goes. Edited September 8, 2009 by Alanw Quote Link to comment Share on other sites More sharing options...
Alanw Posted September 8, 2009 Share Posted September 8, 2009 Just installed the ubuntu 9 GCC 4.3 x86_64 build on my Fedora 10 box and everything works great, so no help there. The only time I've seen the error you posted was during an accidental install of 64 bit Houdini on a 32 bit Linux machine. Are you positive you installed 64 bit Ubuntu? You could try running ldd on houdini-bin. cd /opt/hfs10.0.390 source houdini_setup_bash cd bin ldd ./houdini-bin Quote Link to comment Share on other sites More sharing options...
