Creating (rendering) displacement / height maps from 3d geometry?
rd1010
I'm interested to create my own displacement maps from 3d geometry, for example if I had 3d text I would want to take a render of it and then use that to create a displacement map.. I'm not sure exactly how to do this and am having trouble finding tutorials but I gather it is possible by taking a render with the correct lighting and somehow converting it to the black to white shading necessary for the height map. Has anyone else done this... any links to a tutorial or other info? thanks for any help
I've found it handy to do this with raytracing and mantra -u http://odforce.net/wiki/index.php/ShaderUnwrap.
You can trace out a ray from the surface you want to displace and return the distance to the template object. With mantra -u, you can store this value in your texture. If you use a 16 or 32 bit floating point image format for your texture (exr, tiff, pic), you can get extremely close to the exact shape of your template object.
I attached a little example of transferring hi res geo to a displacement map on a low res mesh using this technique.
Edited by brianburke
