modeling plugin
Hi, I'm new to HDK and maybe I'll be using bad names for things in houdini, so I'msorry for it :) I'll do my best to describe the problem clear :)
So my queestion is : Is itpossible to write plugin with HDK, that will do something like that:
When I will press shift+drag edge it will extrude it?
I only want to know what are possibilities of HDK and if I can change "a lot ofthings" in Houdini with it :)
Thank you very much :)
