Problem: Volume Fluid breaks
Macha
What's your box size and step size?
You might also be running out of ram, are you caching to ram or saving out the sim to disk?
Also that collision object looks like a NURBS object, not sure if that is supported right in DOPS, though it seems the SDF was created for it.
Edit: Wrong thread :-D
Box size was anything from 20 to over 200, and step size I went up to 100. The volume breaks at different frames for different settings, but always breaks at some point. I think it has to do with the RBD collision, for which I also increased the steppings.
I'll try playing with ram settings then. It's a fairly simple scene!
