Measuring distance in POPs
Hazoc
Hello
Do you know why my particle tails won't quite fade linearly and maintain that fade ? They should get their color intensity based on the distance to their parent particle.
They seem to loose that nice gradient soon after they move away from the emiting point.
I don't see what's wrong in my expression in child_color node:/
Thanks.
split_fade.hipncFetching info...
1. there is a line break in your expression?
2. poppointid's second argument needs to be a string.
3. your are using distance to measure the distance between the parent and the parent.
4. you are using fit01, which means you are fitting from 0-1. in this case you are normalising distance not remapping a normalised value.
5. the split pop wasn't preserving the child group
It would probably be easier just to use $LIFE, but it depends on what you want to do i guess...
split_fade_2.hipncFetching info...
