rurik Posted October 18, 2012 Share Posted October 18, 2012 Hello I am using the following commands to setup my command line render using Hython hou.hipfile.load("myhipfile.hip")mantra=hou.node("mymantradrive")mantra.render()[/CODE]It works fine, but I get no updates in the terminal as to which frame is being rendered. I can't see to find the equivalent of the hrender -v in hython....what would that be?ThanksAlex Quote Link to comment Share on other sites More sharing options...
edward Posted October 18, 2012 Share Posted October 18, 2012 On the mantra node itself, change the command from "mantra" to "mantra -Va1" or something like that. Quote Link to comment Share on other sites More sharing options...
rurik Posted October 18, 2012 Author Share Posted October 18, 2012 Thanks Edward, I can see there are some buit in options in the Mantra command... For example Verbose would be -V 1. In this case what is the "a" for? Thanks Alex Quote Link to comment Share on other sites More sharing options...
crunch Posted October 18, 2012 Share Posted October 18, 2012 Hello I am using the following commands to setup my command line render using Hython hou.hipfile.load("myhipfile.hip") mantra=hou.node("mymantradrive") mantra.render() [/CODE] It works fine, but I get no updates in the terminal as to which frame is being rendered. I can't see to find the equivalent of the hrender -v in hython....what would that be? Thanks Alex From a terminal: "mantra -h" shows: -V val Set verbose level (i.e. -V 2p) 0-9 Output varying degrees of rendering statistics p Turn on VEX profiling P Turn on VEX profiling and NAN detection a Turn on Alfred-style progress reporting Then, if you want to render from hython with verbosity from hython itself (rather than getting mantra to report information about a single frame), from within hython: [code] >> out = hou.node('/out') >> ifd = out.createNode('ifd') >> help(ifd.render) render(*args, **kwargs) method of hou.RopNode instance render(self, frame_range=(), res=(), output_file=None, output_format=None, to_flipbook=False, quality=2, ignore_inputs=False, method=RopByRop, ignore_bypass_flags=False, ignore_lock_flags=False, verbose=False, output_progress=False) >> r.render(frame_range=(1,240), verbose=True) 1 Quote Link to comment Share on other sites More sharing options...
