Absorption like Krakatoa for Smoke Volumes
Hey all, I'm curious if there is a way to render volumes such as billowy smoke with absorption . Here is a reference of absorption done in krakatoa http://assets.digitaltutors.com/dtv_/bison_courses/558/detailed_images/5.jpg
I've tried setting up a few lights and tweaking the billowy smoke material but I can't seem to get the right look as shown in the reference. Any advice would help.
Thanks!
Edited by rhussain
Hey all, first post. I'm exploring houdini and I've previously used fumefx and krakatoa for smoke and fire simulation. I'm curious if there is a way to render volumes such as billowy smoke with absorption or some sort of subsurface scattering appearance. Here is a reference of absorption done in krakatoa http://assets.digita...ed_images/5.jpg
Thanks!
I can't see your reference, but you can get volume scattering by setting the "volume limit", in your mantra ROP, to something higher than 0. It comes with a cost though... :D
Also would be ideal to use Micropolygon PBR.
Cheers
  • Like 2
brilliant! volume limit does exactly what I want, it lets the light scatter through. Thanks! Also is there a way to have a specific color scatter through for example yellowish skin color for the outer part of the smoke and red tone for the inner smoke. I'm guessing this is a shader manipulation thing. Or how can I ramp the smoke color based on density (less dense = yellow, very dense = red) I've does this kind of thing with particles color attribute using a vopsop.
Edited by rhussain
  • 8 months later...
Sorry for bumping the thread up, but the question seems really interesting. And we have reference now :)
So is that doable with Mantra? I mean it's probably most certainly doable, but well, maybe someone would like to shed some light on the topic, Mantra-wise. I believe there are clues which could be found in this paper below, but picking them ain't too easy for an average artist like myself:
http://magnuswrennin...Effects2010.pdf
Thanks guys.
post-8633-0-40592800-1375921035_thumb.pn
Edited by Alexander Saraev
  • 2 months later...
  • 2 years later...
