numpy question.
saelly
node = hou.pwd()
geo = hou.pwd().geometry()
for p in geo.points():
    npole = hou.Vector3(node.parmTuple('north_pole').eval())
    pos = hou.Vector3(p.position())
    print pos - npole
"pos - npole" (vector subtraction)
To replace this code with a "numpy", what should I do? (no for loop)
help me plz..
Edited by saelly
import numpy
node = hou.pwd()
geo = node.geometry()
# Add code to modify contents of geo.
# Use drop down menu to select examples.
#get array of all points attr "P" as string buffer...
string_buffer = geo.pointFloatAttribValuesAsString("P", float_type=hou.numericData.Float32)
#create numpy array from our string buffer...
array_of_pos = numpy.fromstring(string_buffer, dtype='float32' ).reshape(-1, 3)  # and reshape to make it 2dimentional (array of vectors)
# doing something with your array... (google the numpy broadcast rules)
array_of_pos -= (20, 4, 2) #per-element operation
#and then you need to copy your numpy array back to points attr "P"
geo.setPointFloatAttribValuesFromString("P", numpy.getbuffer(array_of_pos), float_type=hou.numericData.Float32)
# WORKED (h13)!
Edited by ali
import numpy
node = hou.pwd()
# WORKED (h13)!
Thank you peon!!!
thanks a lot~^^
Have a nice day~!!!
