solver sop animated objects
arifakca
hi,
i succesfully accumulate Cd attribute via animated sphere on a grid. it basicly transfers and keeps color from sphere to grid.
but if i animate grid via mountain sop or transform node , solver sop stops working. it allways shows first frame of animated geometry.
is there any solution for animated object?
scene file is H14 but same thing happens in h13.
thnks.
solverSOP.hipnc
1.In Animated version/sop_solver sop, you are transferring the color on previous frame.This is allowing houdini to remember color info on the previous frame.
2. For position you need live geometry, input_1 node in sop solver. Take position data from this node and use it to set position for previous frame geometry.
solverSOP_Solution.hipnc
Edited by sadhu
  • Like 2
  • Thanks 1
  • 8 months later...
