Setting the display/render flag like in H15.5
If you haven't tried H16 yet, you may find yourself banging your head on the desk because they have changed the hotkey "1" and "2" to set the display/render flags.
They have changed the key and also the way it works.
1. New way, hold "R" and left click on a node to change the display, "T" to change the render flag.
2. In between way, there's a preference called "flag hotkeys work on existing nodes" in network editor preferences. Now, if you press R/T, it'll set the display/render flag without the need of a click.
3. You can update the hotkeys, they're now called set primary/secondary/third flag in Houdini/panes/network editor
          - primary = template
          - secondary = render flag
          - third = display
    If you wish to update these shortcut, you'll have to restart Houdini
  • 3 weeks later...
