HDA - change 'Editable Nodes' via Python
ah-fx
Hey guys,
I am creating an HDA programmatically and I would like to set the value of 'Editable Nodes' which lives on the Node tab within Operator Type Properties. Either HDAOptions or HDADefintion.setExtraInfo() seems promising, but I have not gotten further than that. Has anyone else done this before?
Adam
Editable nodes are stored in their own string section called EditableNodes as a space separated list of relative paths so you can basically just construct your string and add/set the contents of that section to it.
 hou.HDADefinition.addSection("EditableNodes", "foo bar/hello")
