flip stick or glue to geo
dagoose
I'm trying to stick/glue an viscous/gooey liquid (flip) to an object.
This works to a certain degree with stick and friction when the object is static or only translates slowly.
As soon as rotation comes into play the liquid falls off the object.
I guess this is due to the collisionvel. Reducing the force scale in the vol motion tab doesn't do the trick. I tried lots of different settings but nothing really works.
So more or less I am a bit stuck here and hope that you guys come up with a solution.
The general thing I am after is that no matter how fast the object spinns or moves some amount of the gooey liquid stays on the object while other parts may be thrown off.
I attached a simple test file.
Thanks for your help.
stick_rotation.hip
Thanks a lot Karl for your help.
This really does the trick ... funny thing that the 'real' scene which has a character where the gooey flip has to stick on had pretty hres/dense collision geo. But it did not work.
ATM I am looking into grains to get it to behave the way I want. But maybe I will be back to make it work in flip pretty soon.
Thanks again
Rico
