Welcome to od|forum
Register now to gain access to all of our features. Once registered and logged in, you will be able to contribute to this site by submitting your own content or replying to existing content. You'll be able to customize your profile, receive reputation points as a reward for submitting content, while also communicating with other members via your own private inbox, plus much more! This message will be removed once you have signed in.
Bryan
Heightfield Terrain Tile Workflow
Hi - I'm struggling to find a tutorial that explains the workflow for exporting a large heightfield terrain as tiles. I'm unsure where I would use a tilesplit/splice node for example - before or after my erode node? If I have a large terrain with many voxels, the erode takes a lot of memory. Can I use a tile split node before the erode to make the computation less demanding per tile, and somehow iterate over the individual tiles, exporting each tile's maps along the way? If I try to compute the erode on a very large terrain all at once, my pc runs out of memory. I would really appreciate any tips, links or advice you might be able to offer on appropriate workflows for working with large terrains and exporting tiled maps.
Thank you
Bryan
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
