color and attribut from points to VDB
I'm trying to pass the color from polygon to VDB, transform the VDB then apply the color back to polygon but I don't know how to do.
 I tryed to use "VDB advect points" but I can't figure out how it's working and if it's the right solution.
Charles
VDB_color_uv.hipnc
Edited by charly
Hi Tanto,
Thanks for your answer.
So I did what you said and it's working on the first frame.
Now, the problem comes from the advection I guess.
The colors seams to folow the turbulence but not perfectly.
Anyone has an idea ?
  • 3 years later...
Hi, I know this topic is a few years old and I'm not sure about the advection aspect of things but...
I found a very simple way to transfer Cd when using vdbfrompolygons>convertVDB and that's to connect the from color node into 2nd port of convertVDB & inside convertVDB check transfer attributes ON.  As explained by this guy:
