System() Driving Me Mad
Hi there,
I am going CRAZY with system() and how it seems to strip off quotes. I am trying to populate a menu script. Anyone have any good ideas for this, taking the following into account?
Boiled down to an example:
In a file (myfile.txt), put:
"Item A"
"Item B"
Now, in hscript:
Director-> echo `system("cat myfile.txt")`
Item A Item B
Is this a bug in system()? Why won't the quotation marks make it across? I want the verbatim output from the cat command.
Anyone have any kung fu for this type of thing? ...without severely ugly kludges, like nesting quotes "'Item A'".
:angry:
I assume you'd called this ugly
and I've only tested on windows but
\"Item A\"
\"Item B\"
works for me
25749[/snapback]
Unforunately I have little control over the program that prints out this stuff. In fact, if I run this output through "sed", like this:
set cmd = listAssets -c $arg1   #this generates the list (not my prog)
echo $cmd  | sed 's/\"/\\\\\"/g' > $TEMP/exec.sh
set results = "`system("source $TEMP/exec.sh")`
echo $results
(pretty, eh? :unsure:)
..but the problem is, soon enough this output courses through an execute() too - right after the system, the quotes are stripped off once again. There is no way to know how many executes() are going pass this around and so no way to know how many times I need to escape it. In the example above I couldn't figure out wtf to do to get the escaping correct to execute it all in a single line, so I broke it down into discrete steps - hence the added ugliness.
This is a common malady affecting many hscript tools; there is no respect for quotations anywhere. I go crazy with escaping strings all over the place just to push things through. Please SESI, please can we have a real scripting language embedded? No matter what we do we have to eventually end up in hscript and thats where it all falls apart for me.
I think why this is frustrating is that it emulates shell scripting but shell scripting correctly preserves the quotes.
Shell:
%> set a=`cat a.txt`
%> echo $a
"poop poop" "dog"
Hscript:
hscript -> set a=`system("cat a.txt")`
hscript -> echo $a
poop poop dog
It's currently impossible to keep things tokenized in hscript without major effort.
25750[/snapback]
So very true. I have been fighting with hscript all week with similar stuff.
I'm not sure this will be possible in your situation, but could you use a character that does get preserved and then switch it for quotes during the last call inside houdini. So in your example something like this
set results = "`strreplace(system("source $TEMP/exec.sh"),"
