Deleting Duplicate Polygons
I wrote a simple SOP to find and delete duplicate polygons. We run into these occasionally because of over-eager merge SOPs, but mostly because we're getting data from CATIA and other CAD programs that aren't that careful about the modeling.
It works fine for what we need, but I'd appreciate any feedback from you guys as to ways I might speed it up a bit.
Thanks,
Dave
SOP_DelDupPolys.zip
I don't think that you should have to fuse the points to make it work. If I take some geometry and run it through a duplicate SOP and then feed that into the DelDupPolys, it finds all the geometry the second time through.
And the evaluation is checking to see if the points are in the same place, not whether the poly is using the same (fused) points.
What version of Houdini did you compile it under? I was using 7 something.
Dave
Did it under H8. I could send you my test piece of geometry if you like. I put it down to an accuracy thing, if the points are within tolerance you would say the polys were dups but they won't be removed unless the points are fused. My piece of test geometry didn't come from multiple merges or copies so some small errors in point positions must have crept in.
Ah yes. It only find exact duplicates. If you want to use some tolerance, a fuse SOP seems like an easy solution. For what we want, I only want to find exact matches. If you want to make another version of the SOP to add in tolerances, it shouldn't be hard. Let me know if you do and how you do it.
Dave
