Delete primitives with death of particles
Ezz
Hi Houdini-folks :-)
Im working hard to learn Houdini.
And I have been working trough some of the examples found on this page.
So I have a setup containing a logo-geometry that I want to disolve. To do so
I have conected my primitives to a POP-net. I have set the lifespan of the
particles to 5.
My problem is that when the particles die, my primitives are replaces again wich is
kind logical when I think about it.
So I guess I have to put in a delete-SOP to delete the primitives as the particles die.
I need some help to figur out how to get the information from my particles ( $DEAD ??)
so that I can put them in to a group that delete the primtives acordingly.
I hope it makes sense, but I have attached my hip-file so that you can have a look.
Thank you so much
Erik
disolve.hipnc
Hey GW.
Thank you very much for your solution :-)
But if you look closer on the primitives when the particles die, there order is changes and
gives it a rather funky look.
So it brings me back to the idea of transferring the particle ID from the POP-network
to drive a group that controls a delete-node. But I dont know if thats the rigth approach
Erik
What you could try, is to do an ordered sourcing of the points via the prim centers, and then back in SOPs, use a copy sop to stamp that particular primitive onto the particle. You'll need to do the connectivity sop -> partition sop trick as well as to shift the individual primitives to the origin, but I think i should be do-able. Hope you figure it out! I'll try if I get a moment.
Hey thanks for your effort GW :-)
Still its not exactly what I was planning. There must be a way to
transfer the information from the POP-network to a group-SOP which then controls a delete-SOP.
The $PT from the POP-network could give me what I want. I have created an attribute based on that called $KILLPRIM
But I can not understand how to put the information into a group. I have tried all the attribute_nodes there is, to try and combine
the datas..No luck :-(
AAhh my mind is starting to blow
Erik
The Primitive SOP is not as flexible as the Copy SOP in that it can't transfer attributes from the second point input.
You can easily work around this in several ways. The most straight forward way is to use your existing Primitive SOP and the point() expression to index in to the particle geometry. It's straightforward as you have a 1:1 relationship between primitives and points.
See your modified example file attached.
I used a more graceful blending out the alpha instead of cutting them right off before deleting them. I also changed the lifetime of the particles back to 100 as you don't need to kill them off. I replicated the same falloff to the alpha as you had in the death variance. See the "point__dissovle_alpha" Point SOP for that expression in the Alpha field.
disolve_sesi_v01.hipnc
