RBD Fracture Object - Per Primitive Group Activation??
Solitude
Hey all, I have an rbd fracture object with 10 primitive groups, basically I want to active the groups one by one. Essentially I want to control the timing / direction of an object breaking up.. preferably by distance of the prim group to another node. I can't for the life of me figure out how something like this is done in Houdini. Any hints / tips ?
Thanks!
--Ian
Thanks!
--Ian
You'll probably want to use an RBD Glue Object and use an RBD State DOP to animate each piece's Glue Strength.
Search the help for the ChoreographedBreakup example. That should get you started.
Edit: I should add, if you just want to move from Static to Active objects, i.e. they're not moving at all then you want each to one to break off, you could just un-check "Create Active Objects" on your RBD Fractured Object, then use an expression in an ActiveValue DOP to activate individual pieces. I've attached an example. The expression in the ActiveValue DOP ends up being a little complicated, because 1) you need to trick DOPs into calculating center-of-mass and positions on the first frame so you can test those against the sweep plane, and 2) you need to take the pivot into account for each object. There might be a better way to accomplish 1) than what I have here.
choreographedFracture.hip
Edited by johner
Not sure if your breakup is meant be static to active, or something more complicated
Thought I'd expand on johner's reply..He had some great input for me on some related threads.
If position and offset get too complicated ..control the break in sops with a primitive attribute like color.
Use attribute_copy..to transfer color based on proximity to a point/primitive. Then sort through
them by group in a foreach to promote a color from point/primitive to detail then back to primitive
so all the primitives in a debris piece/group have the same color.
Inside a group dops expression access the primitive attribute from sops to setup membership.
prim("/obj/dopnet1:"+ $OBJNAME + "/Geometry",0,"attributename",0) > Threshold
After that use an RBD_keyframe_active to active all the pieces belonging to the group.
Stuff to watch out for.
Keep your groups "clean" when you pull in the debris from sops to dops. ie ..leftover groups can give you weird ghost elements
If you need to subsample...make sure your sop chain has valid values on the inbetween frames..(use a time blend)
Good Luck!
Tom
  • 7 months later...
hi guys,
I find this thread very interesting so i played with this procedural activation, too.
Inside of the SOP Level i created an attribute "myminY" for each primitive based on the $YMIN variable.
Inside the DOPnet i then wrote the following expression in the active field of the active value DOP:
if( dopoption(".", "grid", "Position", "ty") >= point("/obj/dopnet:mygroup_"+$OBJID+"/Geometry", 0, "myminY", 0), 1, 0)
But something must be wrong with my expression, the activation goes crazy inside my scene ...
One other question: if i'm in dynamics select mode, is it somehow possible to see the
(group) name of the selected RBD Object?
Help would be appreciated,
all the best,
Manuel
multicubes.hipnc
Edited by asnowcappedromance
