Field to surface problems
~nature~
Hi,odforce and everyone :P
I need your help,
Is there a way in houdini to reconstruct the surface from some arbitrary SDF Volume and some other fields which is generated in DOPs?
Thanks very much in advance,any advice will be appreciate:D
Edited by ~nature~
extract the field you want
append IsoOffset SOP
set Output Type to Iso Surface
Mode to Volume Sample
Uniform Sampling Divs to desired resolution or use volumeres() expression to get the resolution from the field
maybe you'll need to check Invert Sign checkbox
then just play with Offset slider
Thanks anim,it works.
cheers B)
