willlinks Posted October 9, 2009 Share Posted October 9, 2009 Hi everyone, I got a problem with transfering color imformation from Texture (or shader) to points. I could transfer the color imformation to points but UV is not not match with one I set up. If some one knows how to match UV position, please help me. I attach a sample hip file. Please have a look. Thank you! Quote Link to comment Share on other sites More sharing options...
willlinks Posted October 9, 2009 Author Share Posted October 9, 2009 Sorry, here is the file I attached.... Thanks Quote Link to comment Share on other sites More sharing options...
itriix Posted October 10, 2009 Share Posted October 10, 2009 (edited) the attached file isn't there... try using a uvproject sop then a point sop with a pic function in the color channels, pointing to the image location in cops. look up the pic function to see how to use it also check out this link: http://www.sidefx.co...1423&Itemid=132 cheers, Jonathan Edited October 10, 2009 by itriix Quote Link to comment Share on other sites More sharing options...
