turn off light for secondary rays
is there a way to turn off a light for secondary rays only, so it's effect is not visible in reflections or refractions?
cheers
bmt
With a Ray Bounce Level VOP or getraylevel() vex call, you can manage different behavior of your shader for different ray levels. For example, your object's color can be computed in an usual way only for a primary rays (as seen from a camera), and set to something specific for any other ray (reflected/reflacted/irradianced). Use Ray Bounce Level VOP as a switcher (in SwitchVOP) and connect two colors to two inputs of that switch which is turn goes to Cf. See reflections of that object.
hth.
skk.
cheers
bmt
I modified the Oren Nayer VOP to do this. You can specify a separate Light (or no Light) for secondary rays.
The purpose of it was to be able to render arealight AND irradiance AND Blurry Reflections/Refractions simultaneously and as fast as PBR, but in the normal render engines.
The work flow is:
- Reference copy all the lights
- In the copies set the Light Samples to 1 or 2
- Add the suffix "TRACED" to their names (this causes them to automatically exclude from primary rays and include in secondary rays).
What this does is prevent the light samples from exponentially multiplying. Say you have a 128 sample area light and a 64 sample blurry reflection. Normally what happens is that for each reflection ray it samples the light 128 times, which means the light gets sampled 8192 times! This is why Micropolygon and Raytrace renderers CRAWL compared to PBR.
By setting the area light to 2 samples in secondary rays you kind of mimic PBR's sampling strategy... so 64*2=128, which is the number of samples you originally intended for the light.
I've based our Ubershader around this and the result is same as or better than PBR performance in a given amount of time, but its a pita coz the extra setup means more opportunity for user error.
SideFX could/should? add a "secondary ray samples" render property to the area lights... so we wouldn't have to use shader hackery to get good performance in the standard renderers.
hope this helps
Serg
AXIS_OrenNayer.otl
Edited by Serg
Thanks for the info and the asset Serg!
Edited by brianburke
