HOT install on Intrepid x64, H10.0.401
sanwan
I cant seem to figure out how to compile it... ive tried to run the scripts and followed the steps on the google and the wiki... but nothing is happening and i am getting errors along the python step?
/usr/home/training/houdini-ocean-toolkit/src/3rdparty
root@training02:/usr/home/training/houdini-ocean-toolkit/src/3rdparty# cd ..
root@training02:/usr/home/training/houdini-ocean-toolkit/src# python setup.py bdist
---> pavement.bdist
---> pavement.build
---> pavement.clean
remove SOP_Cleave.o
---> pavement.build_sop_cleave
hcustom  -e -I 3rdparty/linux/include -I 3rdparty/include -L 3rdparty/linux/lib -l blitz -l fftw3f  -i . SOP_Cleave.C
Linking with 'libblitz'
Linking with 'libfftw3f'
Install directory = '.'
g++ -DUT_DSO_TAGINFO='"3262197cbf72461b3786199a46339ff5254985a28f7c87fa59d592554743ed893fde2a8e853269400b13adc7248e310d5eeee406f5d1e15e46043dea67fa98865bbe45a0ff924994a364d41247ba43b3e41aff"' -DVERSION=\"10.0.401\" -DDLLEXPORT=  -D_GNU_SOURCE -DLINUX -DAMD64 -m64 -fPIC -DSIZEOF_VOID_P=8 -DSESI_LITTLE_ENDIAN -DENABLE_THREADS -DUSE_PTHREADS -D_REENTRANT -D_FILE_OFFSET_BITS=64 -c -I3rdparty/linux/include -I3rdparty/include  -DGCC4 -DGCC3 -Wno-deprecated -I/opt/hfs10.0.401/toolkit/include -I/opt/hfs10.0.401/toolkit/include/htools -Wall -W -Wno-parentheses -Wno-sign-compare -Wno-reorder -Wno-uninitialized -Wunused -Wno-unused-parameter -O2 -DMAKING_DSO -o SOP_Cleave.o SOP_Cleave.C
g++ -shared SOP_Cleave.o -L/usr/X11R6/lib -I3rdparty/linux/include -I3rdparty/include -L3rdparty/linux/lib -lblitz -lfftw3f -lGLU -lGL -lX11 -lXext -lXi -ldl -o ./SOP_Cleave.so
Captured Task Output:
---> pavement.bdist
---> pavement.build
---> pavement.clean
remove SOP_Cleave.o
Traceback (most recent call last):
  File "paver-minilib.zip/paver/tasks.py", line 164, in _run_task
    return do_task()
  File "paver-minilib.zip/paver/tasks.py", line 161, in do_task
    return func(**kw)
  File "pavement.py", line 106, in bdist
    call_task('build')
  File "paver-minilib.zip/paver/easy.py", line 78, in __call__
    return self.__get_object()(*args, **kw)
  File "paver-minilib.zip/paver/tasks.py", line 123, in call_task
    task()
  File "paver-minilib.zip/paver/tasks.py", line 241, in __call__
    retval = environment._run_task(self.name, self.needs, self.func)
  File "paver-minilib.zip/paver/tasks.py", line 181, in _run_task
    return do_task()
    return func(**kw)
  File "pavement.py", line 76, in build
    call_task('build_sop_cleave')
    task()
    return do_task()
    return func(**kw)
  File "pavement.py", line 170, in build_sop_cleave
    hcustom('SOP_Cleave.C')
  File "pavement.py", line 192, in hcustom
    assert path(soname(srcfile)).exists()
AssertionError
TIA
Sorry that I'm not outputting a nicer error statement, but the key bit is "assert path(soname(srcfile)).exists()". It looks like hcustom is failing to build SOP_Cleave.C which is a simple SOP with no dependencies and should be no more complex to build than something like SOP_Star.C. Are you sure you have your environment setup properly and are able to build simple sops like $HT/samples/SOP/SOP_Star.C ?
-Drew
---> pavement.bdist
---> pavement.build
---> pavement.clean
remove SOP_Cleave.o
---> pavement.bdist
---> pavement.build
---> pavement.clean
remove SOP_Cleave.o
    return do_task()
    return func(**kw)
    call_task('build')
    task()
    return do_task()
    return func(**kw)
    task()
    return do_task()
    return func(**kw)
AssertionError
TIA
