errors with HOT_Ocean_eval
gyurma
first of all congrats on the brilliant tool!!!! I can and do use the sop however I have problems with the VEX - HOT_Ocean_eval.
I'm getting error messages as follows:
CentOS/linux 64
also the displacement shader (connected to the same issue???)
what am I doing wrong?
Thanks in advance
Gyuri
I'm guessing you didn't use the "hython setup.py bdist" method to build the toolkit ? It sounds like you are missing the VEXdso file which should be on your houdini path. eg $HIH/vex/VEXdso if you didn't use the bdist package method of installation detailed in the documentation.
When you build a binary distribution this is what gets included in the package -
> unzip -t hotbin_linux64_H10.0.407_1.0rc8.zip
Archive: hotbin_linux64_H10.0.407_1.0rc8.zip
testing: hotbin_linux64_H10.0.407_1.0rc8/config/Icons/SOP_Cleave.icon OK
testing: hotbin_linux64_H10.0.407_1.0rc8/config/Icons/SOP_Ocean.png OK
testing: hotbin_linux64_H10.0.407_1.0rc8/otls/HOT.otl OK
testing: hotbin_linux64_H10.0.407_1.0rc8/examples/vop_displace.hip OK
testing: hotbin_linux64_H10.0.407_1.0rc8/examples/sop_flotsam.hip OK
testing: hotbin_linux64_H10.0.407_1.0rc8/examples/sop_simple.hip OK
testing: hotbin_linux64_H10.0.407_1.0rc8/examples/vopsop_foamparts.hip OK
testing: hotbin_linux64_H10.0.407_1.0rc8/examples/vopsop_two_sources.hip OK
testing: hotbin_linux64_H10.0.407_1.0rc8/vex/VEXdso OK
testing: hotbin_linux64_H10.0.407_1.0rc8/dso/VEX_Ocean.so OK
testing: hotbin_linux64_H10.0.407_1.0rc8/dso/SOP_Ocean.so OK
testing: hotbin_linux64_H10.0.407_1.0rc8/dso/SOP_Cleave.so OK
No errors detected in compressed data of hotbin_linux64_H10.0.407_1.0rc8.zip.
-Drew
CentOS/linux 64
Thanks in advance
Gyuri
Edited by eloop
I'm guessing you didn't used the "python setup.py bdist" method to build the toolkit ? It sounds like you are missing the VEXdso file which should be on your houdini path. eg $HIH/vex/VEXdso if you didn't use the bdist package method of installation detailed in the documentation.
-Drew
you were right, that was the problem. Thousand thanks!
Gyuri
