Capturing Number of primities or points of a group in another node
As I said, you use the list of points in the group as an argument to argc() which counts the entries and gives you the number of them, aka number of points in the group. There is no direct expression that gives you the number of points in the group. Attached is an example.
Also, it's not possible to access other nodes local variables. Local variables are LOCAL and can only be accessed from that node, which is why you have to use an expression.
numpoints_in_group.hipnc
