Using 3Delight
Hi all. I'm new to houdini and would like to know how I can use 3Delight to use custom shaders to render.
Houdini version:
latest v10 build 32bits
Platform:
windows vista
3Delight: (I have no renderman)
v6.5
I have found my houdini.env file and added the following lines to it.
HOUDINI_DEFAULT_RIB_RENDERER=3Delight6.5
HOUDINI_RI_SHADERPATH=C:\Program Files\Side Effects Software\Houdini 10.0.401\houdini\ri_shaders
reference:
http://odforce.net/wiki/index.php/3DelightSetup
http://www.3delight.com/en/uploads/docs/3delight/3delight_24.html#SEC34
I thought this has done it but i believe it hasn't set up correctly yet..
I have no experience in building network of nodes in houdini before so excuse my noobness.
is there a good tutorial somewhere to set up my custom .sl shaders and use within houdini with 3delight?
Thank you.
