CSN0309 Posted October 31, 2009 Share Posted October 31, 2009 (edited) Hi~ I use turbnoise node to create this basic white and black effect, but how can i add more details only in white areas? for example add more turbulence and noise. Thank you~ Edited October 31, 2009 by CSN0309 Quote Link to comment Share on other sites More sharing options...
aracid Posted October 31, 2009 Share Posted October 31, 2009 Hi~ I use turbnoise node to create this basic white and black effect, but how can i add more details only in white areas? for example add more turbulence and noise. Thank you~ Hey There That's a good case where by multiplying the output of your turbulance noise against something with a higher frequency, you can get the results described. The file : multiply.hip Hopes this helps Brian Quote Link to comment Share on other sites More sharing options...
CSN0309 Posted October 31, 2009 Author Share Posted October 31, 2009 thank you aracid,, Quote Link to comment Share on other sites More sharing options...
