NITIN Posted November 17, 2009 Share Posted November 17, 2009 (edited) Below is the link that i have downloaded from "houdini exchange". on opening the scene every thing works as expected, except on thing. In the "merge_fluid_geometry_fluid" SOP there is particlefluidsurface node connected to dopinport1. looking at the dopimport1 in detail view i can see the velocity(v) and Cd attributes been transfered. and the data updates as the time changes. same data is supposed to be transfered to particlefluidsurface node as it is connected to it and ....as there is "v" and "Cd" entered in its attribute parameter. Now.... on viewing the particlefluidsurface node in detail view. i can see the velocity "v" and color "Cd" attributes transfered on it. Till here its fine..... the only problem is that attribute "v" and "Cd" are initialized to 0,0,0 and 1,1,1.... and they do not update as time changes. so the color of fluid surface that is generated by particlefluidsurface node remains 1,1,1 (white)...... according to scene description it should be two different fluid coloured RED and GREEN ...and as they merge the colors also blend. hope you have understood the problem...and if someone has any idea why this is happening PLEASE HELP ME. http://www.sidefx.com/exchange/info.php?fileid=536&versionid=536 Edited November 18, 2009 by NITIN Quote Link to comment Share on other sites More sharing options...
