transform manipulator problem
peja_
hello,
when i go into point selection mode with a simple grid, i get gizmo that looks like this
http://dl.dropbox.com/u/1911899/houdini1.jpg
and that is ok.
but, when i do it with a tube, i get something like this
http://dl.dropbox.com/u/1911899/houdini2.jpg
it looks ugly and it seems it is viewable only from certain points of view
this is what i see if i rotate the view just a little bit (i didn't touch anything else)
http://dl.dropbox.com/u/1911899/houdini3.jpg
(it can be even worse from some other angles)
how do i fix this? can it always be as in pic #1?
thanks
Edited by peja_
The problem is that you have non-uniform Object level scales on your geometry and haven't readjusted your viewport to take that into account. If you hit the H key inside your scaled object it should reset your viewport and everything should appear normal. You will of course have to hit H again when you jump back out since your viewport will now be funny because you homed inside the scaled object.
nope, it's not reseting it...its always the same
but you are right about the problem - it is because of the scaling. i tried right now to 'over scale' that tube and my z axis manipulator is now huge. i'm just unable to reset it...any other way maybe?
and thanks for super-fast reply :)
Not sure then. When I scale a tube non-uniformly and then dive in, Space + H to home resets things fine for me. A way to avoid this is of course to not scale it at the object level and do it using a Transform SOP. Not sure what else to suggest.
