particles bgeo delay
vbk!!!
to reference a padded file correctly you'll need to re-pad the frame number after the offset, you can use the padzero() expression for this, since it's a string you need to surround your expression with backticks in order for it to evaluate properly.
particle_`padzero(3, $F-1)`.bgeo
