gshady Posted June 12, 2003 Share Posted June 12, 2003 Hello, how can I do a stereoscopical rendering? Thanks a lot Giuseppe Quote Link to comment Share on other sites More sharing options...
old school Posted June 12, 2003 Share Posted June 12, 2003 I am assuming rendered pics. As for supporting sereo vision goggles, nope. I don't know if this is what you are looking for but for Imax stereo renders, you place two cameras in your scene separated apart to simulate our eyes then render out from each camera individually interleaved. Set the framerate to the appropraite value, say 60 frames per second. You do this in the Global Animation Options dialgue. To access this, you have to press the square button at the right of the play bar to unstow the range gadget then press the "+" button to the right. Create two mantra drivers. The first renders on twos starting at frame 1, the second driver renders on two's starting at frame 2. What is the target output device? Quote Link to comment Share on other sites More sharing options...
chang Posted June 13, 2003 Share Posted June 13, 2003 (snip)say 60 frames per second. (snip) The first renders on twos starting at frame 1, the second driver renders on two's starting at frame 2. Wow, you enlightened me. I had no idea they do this trick. Thanks ! Quote Link to comment Share on other sites More sharing options...
gshady Posted June 13, 2003 Author Share Posted June 13, 2003 Hey, thanks a lot for this great trick! The target output device? Now I haven't info about it Bye Giuseppe Quote Link to comment Share on other sites More sharing options...
