fractured problem
imoh3n
hi,
to keep things simple you could set your creation frame in the RBDfracturedobject
to 19 because by default it loads in geometry only once.
If you really would like to do this whole thing procedural then you would have to
set your creation frame to $FF. However as you will see now the solver creates
objects on every frame based on the incoming geometry, which will lead you to a
whole bunch of boxes.
There is a solution for this. You could load your geometry once at the time the
two groups part_0 and part_1 are created and then delete the geometry the next frame.
So you have to create an attribute which determines the specific frame. However Houdini
apperently finds it hard to memorize frames at SOP level, I haven't found a solution
to this yet, but I'm interested in this too!
One expression to start with would be to look if there are 2 part_ groups:
argc(primgrouplist("/obj/box_object1/partition1")) == 2
have also a look at this topic to get you started:
http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=17699&highlight=
One thing I was wondering: I couldn't find a way to keep the boxes from sinking into each
other, even if i was to increase the geometry's subdivision, upper the ray intersect divisions and
set the surface representation from points to edges ?!
all the best,
Manuel
fractured_2.hipnc
