Overlapping geometry
Macha
Here's a seemingly easy problem but the solution evades me.
I have a bunch of simple shapes (say spheres) copied onto a cloud of scattered points. The resulting geometry has obviously got many many overlapping, intersecting polys. Is there a way to create a clean, yet precise surface out of this? I tried cookie, volumes, foreach, etc but I seem unable to create a simple, clean, light surface out of it.
Any ideas?
  On 12/27/2009 at 2:16 PM, kubabuk said:
Have you tried to use an isoOffset sop? I find Minimum mode to work quite well in certain scenerios.
Thanks but I have tried all of these methods before. If you put down a delete node with a box boundary you can see inside the resulting geometry, and it is quite convoluted, especially for more complicated geometry. :(
I have also tried running each sphere through a foreach sop with an isooffset inside, hoping to get a cleaner volume, but it doesnt help.
The reason I want a clean geometry is because I would like to use a boolean operation on it (to cut through).
If somehow I could find a way to let the isooffset only recognize the very first surface it encounters, and ignore all the inside geometry...
Isoofset with a point cloud is the best so far but the problem with it is that I can't use a negative offset value (why not?), otherwise I could have used it as an input to create a group slightly smaller than the original geometry and use that to delete superfluous points below the surface.
Ok, a different approach. It accumulates new element on each iteration and union-cookie it to the the base geometry. The mesh seems to be clean so it is closer to what you are after, I hope... You can get very same result with the feedback sop (proto_install) The difference is that feedback sop is time dependent.
Cheers,
Kuba
accumulate_loop.hipncFetching info...
You can use a volume-based approach with the ForEach SOP. Create a volume that is big enough to contain the copied geometry, then successively union in the SDF for each object using a VolumeMix set to Min inside the ForEach loop. Edit: so "Merge Results" is off for the ForEach SOP. Edit again: and oh yeah, isosurface the result :)
See attached.
union_volumes.hipFetching info...
Edited by johner
