mabulazm Posted December 31, 2009 Share Posted December 31, 2009 Hi guys after long time trying to find a solution but I could not, so I need help I have a fluid object hitting a RBD, what I need to do is when the RBD object pushed toward to the wall, it is shatter to pieces when it is hit the wall, so everything working with me except the shattering part. I tried to switch between RBD object and RBD Glue but no luck. cheers Quote Link to comment Share on other sites More sharing options...
effectsgeorge Posted January 5, 2010 Share Posted January 5, 2010 leave the object as an rbd glue object from the beginning and only keyframe the strength of the glue. if the groups are being red in fro the glue object then it should shatter. Quote Link to comment Share on other sites More sharing options...
