smoke based on impacts
e=mc^2
check Use Deforming Geometry on your dust static RBD since you are changing it's position in SOPs and that's deformation
or you can move your dopfield() expression to translate parameter of dust object instead of xform sop inside it
EDIT: and maybe change the order in merge1 DOP from (ground,smoke,sphere) to (ground,sphere,smoke) because you have set relationship to Left Inputs Affect Right inputs and so it makes more sense that sphere affects smoke and not the other way.
Edited by anim
