mixing fluid emitter with different colors??
NITIN
hi everyone
i have tried mixing two particle fluids emitted from two different "particle fluid emitter".
it works fine and the fluid interacts with each-other properly.
the only problem is that i do know how to give two different colors to the fluid.
i also know how to use "gas diffuse" node to mix colors.
but could not figured as to how to get the two emitters to emit different color particles.
digital tutor has a course on this....its called "introduction to fluids in houdini"
thanks
